Hi there fellow Hubbers
Anyone came across this specific issue before?
I have searched the interweb and found some other guys having the same issue as i have.
Chris King BB and SRAM XX crankset compatibility issue.
I have installed the CK BB exactly to spec, and then the crankset as well, using the instructions to a T.
Initially, the BB gives as much drag as to be expected from a CK BB, then later in a month or so, I feel a side to side rock / play.
It feels like it is IN the BB bearing, and that after very precise installation, spacing and torque.
My spacing came out to the following:
No 2.5mm BB cup spacers as I have 73mm BB shell.
Drive side; Used all 4x of the CK provided 1mm spacers, disc ring
Non drive side; Used the provided adapter sleeve for the spindled part to go through the bearing spindle sleeve.
PLEASE, anyone came across the same issue, or even better, a possible solution???
Looking forward to hear from you
