Ok. Maybe really silly Q but can this work? I realise that the wheel base will increase but woudl you be able to make it fit? I have soem older anthem swing arms around and the geometry seem to be the same. Sure the layout of the support have changed and the actual linkages changed but it appears the 3.5inch swingarm and 4inch swingarm are interchangible. Does anyone have one to try this with? Would be really cool if it could. Buy a 29er swingarm and change your bike to a 29er. Am pretty sure the 29er fork will work on the old front triangle.
I realise the geo would change. but it may work? Maybe a small front triangle will be like a medium once mated with the 29 swinger, or vice-verca. Would be nice to know if it will work. The 26inch carbon frame I have may make a nice ride for not too much moola :D
