SiCCC Bicycle Brake Rotor: Silicon Carbide-Ceramic-Carbon
So just when you thought you had all the bling you could ever need... $150odd for a set...
http://www.kickstarter.com/projects/kettlecycles/siccc-bicycle-brake-rotor-silicon-carbide-ceramic?ref=popular
Blurb:
What is SiCCC?
SiCCC, is a Silicon Carbide, Ceramic, and Carbon fiber braking material developed specifically for cycling. Our goal from the start was to create a more reliable, better wearing, lighter weight brake rotor. Silicon Carbide for friction, Ceramic for heat, and Carbon fiber for strength.
The SiCCC disc rotor braking surface provides a level of power and progressive feel that equals or surpasses the best conventional rotors. The progressive power is excellent; not much lever effort is required, and the response is quick but not over-the-bar grabby by any means.
The SiCCC disc rotor braking surface is a non-metallic composite and it is thermally inert, meaning it doesn’t expand and contract as all metal rotors do. There is no heat-induced stress distortion on the disc.
This performance is available instantly: no warm-up needed.
Hot or cold. Wet or dry.
All of this and a serious weight reduction.
This can translate into improved suspension performance due to less inertia and handling at speed by reducing gyroscopic effect. The average rider noticing this science at play is debated, the joy of a turkey-gobble free bike that is also lighter is undeniable.
