I have both, like using the rcx, however is there a way to use both at the same time? That way i use the rcx for my day to day and syncing and analysis as it is multi sport etc and use the cs just to look down while riding to view speed and distance etc
Should be fine - the 2 receivers should work fine using the same sensor signals as there is no 2 way comms between sender and receiver as I understand.
Set them up and test individually and try it out.
