Hi,
I have a set of Avid XX brakes, but need to replace one hose.
I have a bit of an issue at the caliper end. There is a Banjo fitting that seems like it is factory attached (or with a fancy tool) to the hose.
I do have a long enough hose to use. I guess I will be able to fit the Lever side easy enough, BUT, what do I do at the caliper side?
Do you get similar banjo fittings that you can attach to a hose yourself? post-5681-0-15482100-1373998153_thumb.jpeg
(Please see the attached pic for the fitting)
If so, any idea where I can get it in the Centurion area or online?
There is one complete replacement set for sale at Wantitall, but for almost R1000!!! Not willing to go that route. Importing such a set is also an option, but with delivery and taxes it will be more than R700. Also not an option.
Any help/advice will be appreciated!
