i have a bryton rider 40 and was looking through my settings and bike profiles, what exactly is the "wheel" setting for and what is it meant to be? the default is 2040mm?
Wheel circumference. Usually set to use with a speed sensor. It's optional if you use your bike on an indoor trainer..... so you can get an indication of distance while on the IDT. Or some people feel they prefer the speed sensor reading over the GPS speed. In my opinion. ..... use it if you have an indoor trainer. ...... if not. Stick with GPS
  • 2 weeks later...
