Hi Guys,
I have a merida big 9 and have a broblem with my rear brakes. its fitted with Shimano M505 and the rear break take very late, almost to grip. i have tried most things to adjust but cant get it any better. front brakes are perfect. Any ideas?
One key "tip" that helped me at the time was the rolling of the membrane back onto the reservoir before putting the lid back on, this helps reduce any air trapped under the membrane.
I had a similar issue a while ago. It turned out that the spacing was not done correctly when the brakes were fitted, so the pads wore down partially. I would look at the pads from the top without taking them out, thinking that they were ok, but once I removed them I noticed a nice big groove on both brake pads creating a nice little pocket where the rotor was free-floating.
