Do it. I'd suggest a 36 if you're an aggressive rider (and if Fox made them in 29") but the 34 should do you fine. The difference in stiffness over a 32mm is quite marked.
Your other option would be a Marzocchi 55, but you'll pay a bit of a weight penalty. If durability's an issue, the Marz wins hands down.
121 kgs..
I would go with 34, but I don't think you will have a problem riding 32 either - got a couple of heavyweight mates at about 115kg riding standard 32mm forks without issues - even during the Epic this year.
