Where can I find a tuning kit for my Manitou Absolute+ damper in SA? They are on the web, but at prices I can't afford. I don't need the full kit, as I only want to play around with the damping until I get it right, and then use those shims only.
Try a motorbike shop, preferably one near a racetrack. If they don't know they'll be able to point you in the right direction,
They're the only other types that play with shim valves in suspension, so they should have shims. Otherwise you're back to your original problem of having to order a whole box because you don't yet know which 3 you'll need.
