Hi Guys,
Buying a XX1 crankset for a Scott Scale Pro 29er - size small and wanted to check which q factor is right for the bike?
Anybody know?
Scott's website doesn't have it.
Haven't got the bike yet to know and want to order crankset right away.
Thanks in advance
On Scott's website looking back at 2012 model it has down the crank as the Sram 2x10 gxp etc etc.
Then when downloading the manual for the 2012 model on Scotts site - mentions bb30 :eek:
Did some googling
http://forums.mtbr.c...c-746412-2.html
"I'm not sure if you've already got it figured out but you need the GXP XX cranks, 156 Q factor, and the SRAM GXP MTB Press-Fit BB (do not us the supplied spacer)"
http://www.marathonm...er-first-rides/
"SRAM XX chainset, 39-26, for the narrow Q factor, with pressfit BB92 bottom bracket"
http://weightweenies...hp?f=5&t=126608
Drivetrain: Sram XX1 with 32t ring and 156mm q-factor cranks
http://www.mountainbike.nl/forum/viewtopic.php?f=9&t=107511&view=previous
heb een scale uit 2011 en rij met de Q156. Maar waarom vraag je het niet aan je dealer?
Edited by kosmonooit
Just to confirm - cause im sure I looked at similar websites, can anyone else confirm? Is it definitely the XX1 GXP 156 q factor crank for the 2012 scott scape pro hardtail?
kosmonooit - thank you very much for your help!
Sure, always up for a 'seek & find' google challenge :) you just have to believe the answers are out there somewhere in cyberspace.
It seems it is GXP type as well, with press fit bearings but I would call the tech support at the agents here to double check, not sure who they are.
