Front Deraileur S3
Guest Smimby
I called Cape Cycle systems and they don't have stock nor will they bring in X0 FD's of the type I need. The X7 will arrive on mid November only.
Does anyone know where I can find the following FD
Sram X0 LOW direct mount  S3 36T Bottom pull.
It is for my friend who wants to replace his current 24/38T chainrings on his Spez Epic 2012 Carbon with a 22/36T but in order to do that he needs a new FD and I can not seem to find any in SA.
Can Anyone help? New or 2nd hand.
I have a X0 second hand but its a S2 - not sure if that will work?
I am trying to find out what the difference is between the s2 and s3 but can not find tech spec
could you perhaps send me a picture?
Okay - don`t have it with me at the moment, best I can describe it you look at the two mounting screw lugs from the top they are offset - one stands higher than the other- don`t know if that make sense, its off a Cannondale Flash - also a bottom pull 36t direct mount.
Otherwise I will try get a pic to you later if need be.
Will do some more digging and see what I can find and let you know
