Can I put a 10 speed 105 crankset on the tiagra 9 speed groupset
Brickleberry
Yes. Will work 100%. I run a 10-speed crankset with my 9-speed setup. Cranksets are generally not 'speed' specific. You may just need to adjust the limit screws slightly of your front derailleur.
  • 2 weeks later...
The difference between 9 and 10 speed is not really noticeable thats why some may think it is not generally speed specific. But there are differences.
You will be fine mixing 9 and 10 speed in this case. I will however not use a 11speed crank with a 9spd chain.
The chainrings are closer together, the chain will rub against the pickup on the big chainrings when you are in the small chainring, trying to pick the chain up and dropping it again... doesn't work.
Phew, i was searching the internets for hours then decided to check here and wow, i want to run a Tiagra FC 4650 crank with my 9 speed group. Thanks guys
