MTB Tubeless tyre repair
Stark
they should last.
you can also patch it from the inside.
remove the tire, give it a proper clean and rough up the area with some 120 grit sanding paper.
stick a normal patch and let it dry properly.
refit your tire and bob is your uncle
edit: the plug in the sidewall could be in deeper
