Best Value for money 29er Hardtail R16000 max??
LouisS
Anyone recently did some research on the best value for money 29er hardtail under R16000. At this stage it looks like the Silverback Sola 2??
SOLA 2 TECHNICAL SPECIFICATIONS
FRAME: 29” Butted 6061 Aluminium, Tapered 1⅛” – 1.5” headtube, 135mm QR Dropouts
FORK: Rock Shox Recon Gold TK29, 100mm Travel, Alloy Steerer, Remote PushLoc, QR15 Dropout, Diffusion Black
RIMS: Alex MD21, 32H, Stainless Steel eyelets, Polyurethane Rimtape, Black, Custom Sector Decals
HUBS: Rear: Shimano FH-RM66, Centre Lock Disc Mount, Adjustable cup and cone angular contact bearings, Cassette, Black Front: Shimano HB-M618, Centre Lock Disc Mount, Adjustable cup and cone angular contact bearings, 15mm Axle, Black
TYRES: Maxxis Crossmark, 29” x 2.1, 60TPI
SHIFTERS: Shimano Deore, 2x10 Trigger, Black
FRONT DERAILLEUR: Shimano Deore, Double, Top Swing Clamp-on 34.9mm, Black
REAR DERAILLEUR: Shimano XT Shadow Tech Plus RD-M786-SGS, Long Cage, 10 Speed, Silver
CRANKSET: Shimano Deore, 38/24T, L: 175mm ALL SIZES, Black
CASSETTE: Shimano CS-HG50-10, 10 Speed, 11-36T, Silver
BRAKE SET: Shimano BR-M615 Open Hydraulic System, Rotors Front: 180mm; Rear: 160mm, Centre Lock, Black
SADDLE: Sector, Cr-Mo Rails, Light Foam Padding
HANDLEBAR: Sector Plane, W: 700mm; Back Sweep: 9° x ∮31.8mm; 6061 Butted Oversized
STEM: Sector Reach, S: 80mm; M: 80mm; L: 90mm; XL: 100mm, 7° x ∮31.8mm, black
SEATPOST: Sector Plane, ∮31.6mm x 400mm; Black, Black bolts
The 2015 Merida Big Nine XT edition has some decent specs and a RRP of R17999, but I saw several of them on the floor at Northcliff cycles marked at R16,500, if you are willing to squeeze just over the R16k mark.....
