Fox f29 rlc fit- won't pump?
maakaplan
Any advise will be appreciated on what is going on with my fork.
I realeased the air out my fork and now it won't inflate with the fork pump.
Cheers
Mark
That depends on how you let the air out. I'd assume you just depressed the pip on the valve, in which case I'd try a different shock pump, or try screwing it on tighter.
If you believe you've done something silly, let me know what it is and I'll advise accordingly. Or just bring it in if you're in the area and I'll have a look for you.
