Front wheel Bearing on Pro-Lite Aneto wheelset
johanpre44
Just want to check if anyone knows how to replace the front bearings on a Pro-Lite Aneto? The bearings are actually very dry and one of them is running a bit rough.
As far as I can see its a couple of 6805 bearings that is pressed into the hub with a 25mm OD axle pressed into the bearings.
I have the necessary pullers/presses.  I charge R85-00 labour and the bearings are additional.  I have the ABEC5 in stock (R200ea) but can get the ABEC 3 which are R115 ea.  Contact details on my profile.
