Brake Bleeding Kit
JJDT
Anyone bought this product to service their brakes?
Icetoolz Universal Bleeding Kit, currently on special at CWC.
Last question is that I do not see that they mention Shimano...compatible...
I bought one a while back - not great but it does have a lot of adapters for various brakes. Disadvantage is that it had very limited tubing and no clamps that you need for Avids. Also not great syringes. For Shimano a better bet is to get hold of veterinary syringes and some decent tubing. If your brakes are the type that need the cup that screws into the lever end then rather get the Shimano part. I think Buycycle has them. For the older Shimano you just need two syringes, a 7mm spanner, a bit of tubing and the mineral oil.
2 x 50ml syringes =R20
0.5m tubing from brights=R2.50
Use the white pointy lid on shimano mineral oil and just cut the tip off, its plastic so it screws into the lever perfectly. There you are.
