Bike check: Specialized Hotwalk "S-Works"
Nick
Spec:
Holes cut out of the frame to run an internal brake line, also fork steerer lengthened and rewelded to run threadless headset and a shim needed to clamp the stem on to the 1" steerer tube. Powder coated satin black with red stickers.
  • 1" M Part threadless headset.
  • Carbon stack spacers.
  • Hope 50mm stem.
  • Specialized carbon cap.
  • Carbon flat bars 470mm
  • Octane mushroom grips cut in half and joined.
  • Hope Race Evo stealth brake with internal routing using orange 5 grommets.
  • Hope rotor 140mm.
  • Hope pro Evo2 front hub modded to fit the rear.
  • Hope mono front hub modded to fit front.
  • Hope quick release front axles front and rear.
  • Original rim relaced with cut and rethreaded DT Swiss spokes with red nipples and just put a roval logo on the rims to add the looks and then dice valve caps.
  • Specialized rhythm lite 12x2.0 tyres.
