Headset Bearings for Specialized Epic
zniper
Hi
can you buy these kind of headset bearings at  BMG ?
http://2share.co.za/Files/ebc49ff1-487d-416e-b9b7-ebe401bb1715Capture.JPG
also what is difference between
OD:52xID:40xH:7xA:36
OD:52xID:40xH:7xA:45
This is according to Specailized Epic Manual
http://2share.co.za/Files/87d76eed-bb7e-4ce0-974f-e6a1165a6d11Capture1.JPG
You won't get them from BMG.  The difference  between OD:52xID:40xH:7xA:36
OD:52xID:40xH:7xA:45 is the angle at which the bearing contacts the race - one is 45 degrees the other 36 deg. It is best to take the bearing into the shop to make sure that you get the right one because there are a lot of variations of the same thing!  I keep quite a few in stock but we are not exactly neighbours.
