Desparate for help with creaks
BaGearA
Helps to use plumber's tape (white teflon tape) on external BB cups.
Also try and use good quality copper grease/paste on seatpost, steerer column, all bolt threads (non thread lock), pedal fixing bolts, chainring bolts. Also check that the sprocket cassette tight (40Nm)
those darn creaks can really drive you nuts!!!!! always so rewarding when you get rid of them, especially if it only cost you a little time and some grease. :thumbup:
