Connecting iPhone to Wattbike & Headphones
wolver
Hi
Has anyone successfully connected their iPhone to the Wattbike app and a set of bluetooth wireless headphones at the same time?
My google search returned mixed result as to whether you can connect multiple bluetooth devices to the iPhone at the same time and I want to make sure it can be done before buying a set of headphones today.
I can't remember if I used my BT headphones while on the Wattbike. I've gone back to normal in earphones again got sick and tired of charging the BT ones. However.......
Concerning two or more connections over BT. I use a Garmin Fenix 3 which is permanently connected to my iPhone while in the car connected to the BT radio. Never ever had an issue.
Hi
It really depends on the BT your earphones are using... Bluetooth LE can take up to 20 connections. What brand earphones are you using?
