SID XX Dual Air 100mm Travel with Lockout
Beesley
Good Evening All,
On the suggestion from Grease_Monkey to ask about this fork, I have decided to follow the advice given.
Does anybody have an idea of the value of this fork? It's got a bit of wear and tear aesthetically, but just superficial.
Lockout works great but I'm wanting to build up little dirt jumper with a lot more travel.
Your input would be greatly appreciated.
Gareth
It is an amazing fork that, and unfortunately because it is a 26er you are not going to get what it is worth.
I would start advertising at R2500 and see what responses you get.
Someone else that maybe knows a bit more may correct me here, but that is what I would pay if I were in the market for a good 26" XC fork.
Thanks for the suggestion and advice. It's so difficult to assess on a 26 inch frame.
I'll update the ad as well so it's not so ambiguous to read.
Cheers
G
