Replacement pins for Flats
NicoBoshoff
Need those
Apple Tool and Gas in Strand should have this.
I saw the exact same bolts there about 3 weeks ago.  Lots of different sizes so you should be able to find ones that fit.
Need those
Any bolt and nut shop should have those. They look like standard caphead screws. Just be aware that the black ones that you get over the counter are not treated and when exposed to water they will rust. Ask for zinc coated or stainless steel.
Edit: take a sample with (Nut and bolt. You might not be able to reuse the nut after the damaged bolt has been removed. If the end is damaged, it might damage the thread as you unscrew it)
