Novatec Hub Mechanic Question
DemitriN
Do any of you mechanically minded know if these Novatecs are convertible? I need to change the front wheel to a 15mm TA and the back to 12x135mm TA. I think the hubs are D361SB and D362SB but I'm not 100% sure. Thanks so much!
post-60408-0-18421600-1502635729_thumb.jpegpost-60408-0-86682200-1502635793_thumb.jpegpost-60408-0-13125100-1502635877_thumb.jpeg
In both instances, but it in a vice and pop those endcaps off, swop them with what you need
Thank you Meezo. Do you know of any bike shops in CT that carry the adapter caps & thru axles?
Ask Janos at Evobikes, as I know they do Wheel-builds with Novatec Hubs
