Change History
Changes made from version 2.10 to 2.20:
Added more power meter support.
Added ANT sensor detected messages.
Added Max Power, Last Lap Max Power, and Kilojoules fields.
Fix problem with locking up on the map page.
Added progress bar for reading new Saved Ride data on powerup.
Adjustments to reduce speed spikes.
Increased internal route point memory to handle longer tracks.
Corrected ANT-to-ANT transfer page display in night mode.
Fixed issue with backlight brightness adjustment.
Fixed lap averages not being cleared correctly, when user stops the timer, laps, and starts the timer again.
Fixed issue with power wattage not updating.
Added power calibration success/fail messages.
Battery display should no longer show less than 100% when charging is complete.
Added SiRF InstantFix support to increase speed of initial GPS fix.
Fixed issue where pressing buttons would affect altitude.
Implemented feature request to be able to delete all waypoints from the device.
Added a 'Cities' item to the find menu.
Fixed issue where searching for an address lists specific street (Avenue, Circle etc.) instead of generic street name.
The Follow History list is now filtered to only show rides that contain position data.
Fixed issue where some combinations of maps would not work together.
added more power meter support? cool!! :)
