Help! Giant Trance 2 2015 pivot bearings
berg_fiets
  • 1 month later...
UPDATE!
Rushsports now has stock. Get your LBS to order yourself some.
MAX | 6900 FO LLU | 10 X 22/24 X 6/8MM EXTENDED RACE BEARING
If your pivot bolts looks like this (roundish head), then you DON'T need this special bearing.
If your pivot bolts looks like this (flattish head covering the whole bearing), then you need this bearing. Yes, it should be flush against the frame but mine still needs the right bearing fitted at the LBS Monday...
