Piston shaft loose in monarch plus
usxorf
Took the aircan off my monarch plus to do a seal change, and the damper/piston shaft was loose and popped off with the can. If i loosen the air piston from the damper body and use the nut on the other side to screw it back in I should be good, eh?
The eyelet end of a M+ is a fickle beast. Also, make sure you've let the IFP pressure out before you go any further.
Bring it round if you get stuck.
