Garmin Connect - default gear/bike
Griffin
Using Garmin connect/Garmin 520 does anyone know if its possible set up default Gear per type of cycling ?
I have loaded all bikes under Gear (Hard Tail/full suss/road/track)
Its easy enough to set a default bike per exercise type (eg Cycling = default bike x) but that default bike then gets allocated to every cycling type (road/MTB/track)
What I would like to is to have a default bike per cycling type.. so when i selected the type of cycling done the default bike for that type of cycling is allocated.
Had a look at this and thought maybe you can create a new APP (activity) on your device and specify which gear is default ie new activity is "Downhill" then apply DH bike to that, but seems that in Garmin Connect, the new profile activity does not get added to the list in the Gear section...it only lists the Main categories, no sub-categories..when I start my "Bike" activity, it defaults to Cycle after finishing the activity and then I have to select a sub-category on G Connect. The Cycle activity is linked to the Bike in Gear and as you say, you have to then set your change the Gear if you didn't use the Default Gear for that activity.
Would be handy to not have to go through the data for each activity and re-sort it!
