2015 Scott Spark suspension bushes
Lance Roberts
Hi everyone,
I'm looking for a kit to replace all the bushes on my 2015 Scott Spark 910 rear shock. Does anyone know if there is a certain part number for all the bushes, or would I need to buy them one by one at my LBS?
I'm talking about the bushes, bolts and pins on the shock only, not the pivot bearings and all those spacers for the rest of the suspension.
I've attached a picture, not of the same bike, but the shock is the same. The bushes are where the yellow circles are.
Hope someone can point me into the right direction, maybe an online shop who sells this as a kit.
Thanks a lot!
You can get shock bushes at you local shop.
It is available separately to the Pivot kit.
Thanks for the reply
Would I need to take the whole shock in to measure, or are the parts all commonly sized?
Any idea of cost?
Any idea of cost?
I haven't had to do it in ages, so no idea of the costs and logistics. Mine was done as part of a service.
Off the shelf item available from your LBS. You're after 2 x 22.2 x 8mm kits.
The kits are flippen expensive though, so I'd suggest getting the stainless versions - you can then replace just the plastic bits with the Push Industries version at a fraction of the cost.
Any idea if there is a local supplier of the Push Industries components?
Robbie's Bicycle Concept is the distributor, otherwise we and a few other shops keep some of their spares in stock as well.
