Garmin cadence sensor
Andrew doug gemmell
Andrew WELCOME to the forum.
Thank you.
The rightful owner should have a record of his run .... with cadence suddenly going to zero near the point you found it ....  should be very easy for the owner to know when and where the sensor got lost  (okay, on a downhill section it might be out by a bit, but still ...)
