Scott Spark rear triangle.
svacha
Hi all.
These are off the rear triangle of a Scott Spark 710. I need a pair as these as these are cracking, not sure why as I have always only tightened to 15nm. LBS says I have to buy get complete pivot kit at R1949. Any one have a retired pair for sale?
Thanks.
  • 1 month later...
Not sure if you solved your issue:
Yup, I think shop over tightened my bolts too - do all my own servicing now.
But here is what I did,
One bolts still ok but did this for both:
(removed cracked peaces from bolt if they too broken)
Drilled out a washer - add washer to bolt
Add LockTite when refitting
Note - lots of thread still on bolt - so no worries about strength of the repair.
Does build up a little rust - as you can see - but no problem.
