FULCRUM 5 LG WHEEL BEARINGS
Geronimo
Has anyone here changed the front and rear bearings on a set of Fulcrum 5 LG wheels?
I need the bearing numbers, please. I believe that the back takes the same two as the front plus a second pair which is different. Any help will be appreciated.
They have changed slightly over time with bigger axles being adopted.  If memory serves me I think that the axle ones are now 6903 (30 x 17 x 7) and the freehub ones smaller.  Not sure what.  The older ones were 6001 on the axle and 6901 on the freehub. Best to take apart and check.  You don't need to go too deep to get to the bearing covers to get the numbers.  If yours is the older one it is a bitch to get the inner free hub bearing out as it is held in with an impossible circlip. I hope the new one is better.
Hi Geronimo,
I have dealt with JJ Cycling for Bearings and also Fulcrum decals, they can help you because they are the Fulcrum agents in SA.
Herewith the info:
Sybrie Brown Cycling J&J
so@jjcycling.co.za
Zelda Marais
info@jjcycling.co.za
CYCLING J&J (Pty) Ltd
Tel:                  012 807 5570
                        012 807 2812
                        012 807 1672
Fax:                  086 691 2322
Website:           www.jjcycling.co.za
Cheers.
