Garmin 520 Heart rate monitor
Lizzard30
Hi
Is there something im doing wrong or missing? Since my battery died on AMA 100miler ride my heart rate monitor is giving me trouble...
I replaced the battery but ever since on every ride it seems to register fine until about 20mins in then heart rate drops and are giving serious low readings..
I then have to remive it from sensors and re add then it works perfect for another 20 or so mins... then remove and add again... ????
Anyone else experiencing same issues...
Or what can cause this problem...
I did try my other brand new garmin strap from my wifes box.. same story...
Please help....
I havent had your type issues however i did have and im still having issues, i battle to connect my new hr monitor that was replaced by Garmin, eventually it connects and then works fine for the full ride. Im using my wahoo and its magic. Garmin is now for emergencies.
Maybe delete the HR from garmin.
Re-install.
Make sure you using 3v battery.
Hope you come right, its most annoying.
Hi
Please help....
Good day Lizzard30
Thank you for posting your enquiry on Bike Hub
If we have already replaced the battery and tried a different HR strap I would recommend we do trouble shooting on the Edge device itself.
Please could you start with ensuring the Software version on your Garmin device is on the latest version using Garmin express.
If already updated do a Factory reset on the unit and set the device up again.
Good day Lizzard30
If already updated do a Factory reset on the unit and set the device up again.[/quote
Yes its defenitely up to date.. ill try a reset and see if the problem persist or not...thanks alot
Hi.. rode 130km training ride and after the hard reset its even worse...when adding to device it picks it up but does not give me a reading...
This may sound really stupid but it worked for the dropouts I was experiencing on mine.  What CR2032 are you using?  Switching from Energizer to Duracell sorted mine out.
I also think you might be right...because everything started just after i switched the batterie..
