Woolftooth B-Rad mounting base for Specialized Epic
Knersboy
Hi Hubbers
I am tackling 36One next year and am interested in using the Woolftooth B-Rad double bottle adaptor to get more water storage on my bike.
I have an Epic which has three bottle cage holes on the down tube.
Does anyone use the B-Rad on an Epic? I have to choose between the 2 slot or 3 slot mounting base. I would prefer the 2 slot as I don’t like the whole cable tie system on the 3 slot. Will I have enough wiggle room using the 2 slot and the current three bottle cage holes and still be able to fit two 710ml water bottles (and the one on the down tube) or should I go with the 3 slot base just to be sure?
Hi Hubbers
I used the dog bone and the B-rad double bottle adapter
Thanks Ramrod. With that setup could you fit two big bottles? I am assuming that moving the bottles off center of the downtube allows big bottles to fit even though you used the top two holes.
