Long enough and robust enough lever I guess you can bend anything.
For a spinning bike I suggest take the pedal off, slip a meter long bit of square tubing over the end of the crank and go for it. You'll need to either take the crank off and lock it in a vice or somehow chock the flywheel if you want to do it on the bike.
Macsteel do a 32x32 3mm thick one that would probably do the trick. If that deforms, go up to their 50x50 6mm thick one.
Edited by TNT1
