Hi guys
I want to know would a 2.4 Maxxis Recon Race tyre fit on a Specialized Stumpjumper HT 29er? Specifically at the back? I have a rigid fork and that clearance would be enough. Hope to hear from you.
Edited by Regardt van der Merwe
I have run 2.35s on Stan's Flows. These were super close to the frame, and in muddy conditions would result in tub. 2.3s seem fine.
Flows have a 29mm rim width (no internal). This also has a bearing on the size of the wheels that you can use.
