Sorry can't help but how is this fork? I'm looking at a 2023 Trek Roscoe 7 that comes with one (140mm). I know its not going to be a Pike but I'm hoping its not complete garbage.
Hi. Currently only repairing the fork and have not ridden a bike with this fork on, sorry
Howzit man, I doubt that you will find this part lose. It is a common issue on the mid range RS forks for these to brake or fail. You may need to replace the whole damper. I can order one for you if need be. You'd be looking at around R1100 for a new damper
Thanks for the offer. I will go check at my LBS if they don't maybe have the specific part.
^ what he said.
These things pop quite often, and almost always in the same place.
I've sent you a mail, will need the serial # to know exactly which bit you need.
1 hour ago, droo said:
^ what he said.
Thanks @droo. Will send you the number
