  • Replies 35
Speedi, phoning your LBS and telling them your length is very much the same as phoning your doctor and telling him you have a pain in your back and would an Aspro be good enough. You will most likely use a 56cm frame but it is just worth your while to have yourself measured by somebody who knows how to do it. The cost outlay if you buy the wrong frame is just too much. Your LBS most likely used one of the well known formulae and remember that is just a starting point.
I can remember my friend Jacobus so well. His Dad bought him a black dikwiel so large he had to cycle standing with one leg through the triangle. His dad said...."Die kind moet die fiets maar ingroei" Maybe that is what you must do!!!!!!!
Big H2008-09-22 02:17:14
Speedie, since you live in Seaview I suggest that you see Wayne Pheiffer since he is round the corner from you knows a little about cycling as well. He is a really nice guy and very helpful. you could also go through to Uitenhage and see Steven or Brent at Penford Cycles. If you need there contact details you can PM me.
Speedi' date=' phoning your LBS and telling them your length is very much the same as phoning your doctor and telling him you have a pain in your back and would an Aspro be good enough. You will most likely use a 56cm frame but it is just worth your while to have yourself measured by somebody who knows how to do it. The cost outlay if you buy the wrong frame is just too much. Your LBS most likely used one of the well known formulae and remember that is just a starting point.[/quote']
Ok im 1.78 tall' date=' still growing. I phoned LBS and they said i should get a 56cm. Thanks[/quote'] Who did you phone?
Wayne Pheiffer Cycles(BEST SHOP IN PE), spoke to Wayne himself. I ride for there club so ja...I live in Schoenies BTW smiley36.gif Seaview is too far out of town(30km?)
If you look at one of my previous posts that is who I suggested you phone.............and I will mention to Rob Rudman what you said as well! Wink
