I assume you want to offset the disk away from the hub by that distance?
Why not buy some shim stock from a good hardware or machine shop and make a little gasket/spacer yourself. You can get it in brass and with luck you'll be able to cut it with a standard pair of scissors - preferably someone else's scissors. Wink
Actually, 0,5mm is quite thick. Scissors won't work but a sheetmetal shears will.  In that case, go buy yourself some imported beer in a can. Fosters or Boddingtons. Cut a double shim from that can. Two layers will be about 0,5mm. I say imported beer because that's canned in aluminium and it is possible to cut that with your wife's scissors and, it gives you an excuse to try some new beer.
