Anyone know how to pick a Scicon case lock?
Here's the story - I'm borrowing my friend's Scicon race case to go down to do the Herald next weekend.  Said Scicon race case is locked and no-one remembers the combination.
So 1) we've got to get the case open and 2) we need to reset the combination.
Any ideas?
In the inside of the lock(when you have opened it) there is a small lettle 'switch' you have to move....
After that you set the piin and move the 'switch' to the original position...
It is 3 numbers...good luck...(hopefully both sides are the same)
Thanks GFishy - Mandibles suggested getting a locksmith to get the case open.  So once they're open I'll reset them like you said and problem solved.
