After the theft of my Polar S725x, I managed to get hold of a CS400. But it doesn't download to my Polar ProTrainer 5 software. It starts the download, but then aborts it without completing it. Is there a separate software for the CS400? Where do I get it? Is there a site I can download from? (No luck on the Polar site) Other advice?
Hi yang, I have a polar CS400 which I download to Polar pro-trainer 5 with no issues.  Presumably you're using a USB infrared port?  Do you get an error message?
Thanks Nancy- that gives me some hope that its a repairable problem, but I've just downloaded again and the message is along these lines:
Polar.exe 32 has encountered a problem and needs to close.... bla bla... you will lose information bla bla.
I use a laptop with a built in infrared port, no external USB connection. I had no problems with the S725x download.
Yang2009-04-12 12:23:09
Guest Agteros
I think there is a bug in the latest Protrainer 5. I updated mine recently and Polar32 encounters a problem just like yours now. The old V4 software is still running smoothly....
