My good cycling buddy (Greyowl) has donated me a set of 9 speed shifters (Shimano) for my bike which is currently configured for 8 spped Shimano.
Other than Shifters and cluster, what other mods do I need to do to convert to 9 speed.
Do I need to change my chain, freehub all that sort of stuff?
Advice Please. JB, you seem to have the guru status, your opinion will be valued. (anyone else, I need help.)
Thanks.
I ran 9 speed on my 8 speed bike. The only things I changed was the shifters and rear casette. I also took out my smallest chainring on my crank.
I'm no expert, but I did some research when I was still thinking of upgrading my old-school road bike to STI's. I can only offer the opinion of Sheldon Brown:
The hub will be compatible with a 9 speed cassette:
"Shimano 8- and 9-speed hubs and cassettes (except Capreo ) are fully interchangeable with one another, so any 8-speed hub can be a 9-speed, or vice-versa."
From http://www.sheldonbrown.com/k7.html
I'd think a change of chain would also be necessary, as the 9-speed chain is narrower (compared my 9 speed Tiagra with a mate's 8 speed Sora chain - we just added Power Links, so recently noted this).
From my reading, I recall that the derailleur pull ratios are the same for almost all the Shimano group sets (except some Dura Ace sets, IIRC).
Hope this helps a bit.
Cheers,
Andrew
andrewc2009-04-17 03:25:55
