I will be building a track bike to race and need to get hold of a crank and sprockets and a chain.
There seems to be a few different standards ,and BCD's etc 1/8" and 3/32" etc is confusing when you don't know what you need.
Are there rules regarding gearing? I think I'll need a 170mm crank. But don't know what size chainring to get...
Also I need to make sure the BCD I get is compatible with Locally available chainrings in case I need different sizes.
Anyone know what they are talking about here that can help?
tarmac,I just went through the same process:
For track use (as oppose to just fixie riding) get 165mm cranks - you need the clearance on the steeper slopes with the shorter cranks.
BCD - 144 is most common although there are different sizing i.e. 135, 130 etc. So be carefull to choose blades to suit your cranks
track cogs/ blades are 1/8". So unless you run road blades and a 3/32" cog, rather stick to the standard 1/8" setup.
BTW If your chain is 1/8" apparently you can still run 3/32" blades and cogs, but not other way round (just make sure BCD comply to cranks)
Also chain line is important - road cranks will place your chain in a different line than a track crank will do, so rather stick to track cranks and rear hubs
I found a Sungino crankset + blade at Wiseman in dbn for only R250 on Saterday!!!
A very profound statement I got: Track bikes don't have much equipment on it, but what is there is very critical so you don't lose teeth!!!
  • 2 weeks later...
Ok so this project is now off the ground with the the Hub Track series around the corner I need to get it sorted asap!
I have a Specialized Langster S-Works Frame, with Carbon Fork.
Pro Disk rear track wheel.
Pro RC50 Front Wheel - my road front
Truvativ Touro Crank and Shimano BB - Dave Wiseman
Specialized Profit Stem 100mm - Take off from my road bike
I have some bars... and tape is on it's way... thanks Solomons.
Now all I need is a saddle and a chain and rear sprockets... getting those soon!
Yo tarmac
Have you seen the cool specials CWC have on their Prologo Saddles!!!
A White/Red one would look so awesome with that bike of yours!!
I'll have the crank tomorrow and the wheels as well...then I can at least stand it up... at the moment it's swinging in the garage...
then I will take some pics.
Going to get a chain and sprockets tonight...
Damn I think I missed the courier for that, but luckily Bridge cycles have a few bits going there tonight to get chain and cogs.
Marius i sent pm
