Hi there,
I am about to change my road wheels to full carbon clinchers. Is it absolutely essentially that I get carbon brake blocks or can I just leave as is? If I need to change where should I buy?
Thanks,
JD
clinchers doent normally require carbon brakes - use what you have currently.
if you have a full carbon wheel, where the brake block will actually come in contact with the carbon, then yes you need carbon brakes.
