Drill a small hole in the seatpost (using the V notch at the seatclamp)
Thread wire through the hole' date=' and pull
That sounds like a good plan. Have you done it before?
Get one of those spring loaded wall fastners (not a rawl bolt type), screw a threaded rod in, lower into frame until it clips and pull the old seatpost out.
