I have a spez e5 s-works beign built up at the moment at my LBS.
Only problem is that the headset(integrated) was a bit dodgy so I asked them to replace that at the same time. Its been 2 weeks now and they are battling to get hold of a replacement unit. I have also given them the old one which just had some bad bearings in it.
After checking through google I saw that some peeps have replaced the standard one with a cane creek IS2 or similar. How hard is it to get hold of one of those headsets? I could have had one here from CRC by now!
Is it worth trying to get the original spez part instead?
