I have Shim M485 hyd discs with SH-RT53 rotors (160mm)and need to replace the rear rotor since I managed to bend it in a recent bail-over-the-bars. Its a center lock rotor.Does anyone know if i can use generic center lock rotor replacement or do I have to go Shim again ?
Shimano are the only ones that make centre lock rotors, as it is their patent, but any 160mm rotor will work if you also get a centre lock adapter...
