Hi
I am looking at replacing the spring on my rear shock, Rock Shox Deluxe Pro. Since its a bit old, I was wondering if anyone knows if the springs for the Vivid are compatible?
Cheers
Shock springs are an issue on older springs since distributors don't keep stock so far back. Also, if you want to tune the spring you can't fiddle with stiffer or schlapper springs if there is no stock.
If you have access to the Vivid spring it is a matter of measuring the spring wire diameter, count the coils and measure the length.
Otherwise, I just make up the spring to spec.
