Hey Guys
We have set this beauty up for Sani2C & are now going to be cutting down on more weight for the Epic.
The whole drive train will be replaced as well as the handlebar,stem,crank & hubs.
the dual sus 29er should be around 9.5 - 10 kgs at the end.
Looks reallly good - how do you get it to the weight? What size is it, and do you meassure with the pedals, bar-ends, slime, cages etc on - ie the road weight? My X-large 29er came out at 13kg.
It is a large frame(20").I will give the exact weight as soon as the bike is done.The light weight components include a Specialized Reba 120 fork with a carbon crown & steerer,Ritchey WCS straight handle bar & stem,Rotor compact crank & a mix of Sram XO & Shimano XTR components.Hope hoops have been fitted.
