Bike Mob Posted May 6, 2010 Share Cool keep me posted. Silly Mechanic that put a washer in there in the 1st place. Only reason to do that is for a Hope 165mm rotor. Link to comment Share on other sites More sharing options...
R3SL Posted May 6, 2010 Share Between adaptor and caliper. R3SL Link to comment Share on other sites More sharing options...
Bike Mob Posted May 6, 2010 Share http://reviews.mtbr.com/blog/ashima-airotor-review/2/ Link to comment Share on other sites More sharing options...
Bike Mob Posted May 6, 2010 Share Get some sintered pads soon bro...these are going to spit those organics out like yesterday. Link to comment Share on other sites More sharing options...
RossW Posted May 6, 2010 Share Nice review, thanks for posting it! Yea, I will have to get sintered. But having laid out quite a lot of cash on Hope Hoops, Gobi and Candy SL's I'll let these get eaten and then get new pads. Will be interesting to see how the sintered perform in comparison to the soon to be killed resin pads... Link to comment Share on other sites More sharing options...
Weight Weenie Posted May 6, 2010 Share Nice review' date=' thanks for posting it! Yea, I will have to get sintered. But having laid out quite a lot of cash on Hope Hoops, Gobi and Candy SL's I'll let these get eaten and then get new pads. Will be interesting to see how the sintered perform in comparison to the soon to be killed resin pads...[/quote'] Look here as well - http://www.gramslightbikes.com/2009/08/ashima-airotor-review.html Sintered will modulate less and make more noise from what I hear, also a gram or two heavier ? But the longevity is better, the organics in my R1's are really showing some wear, only got them end last year. But I'll keep running them with the formula rotors, work well that way. Link to comment Share on other sites More sharing options...
RossW Posted May 7, 2010 Share Maybe then the best is the semi-metal ... I believe it is sort of best of both worlds. Link to comment Share on other sites More sharing options...
Weight Weenie Posted May 7, 2010 Share Ashima make pads as well 'sos' with a dual compound organic and sintered mixes, maybe try those with their rotors Link to comment Share on other sites More sharing options...
RossW Posted July 12, 2010 Share Been using the discs for about 3 months now and am very happy with them! On some decents the heat generated is insane (nice smell) but the stopping power does not decrease significantly. I did at one stage though feel that I wasn't going to stop in time but in the end not a big worry as things worked out. In a nutshell, if you want "cheap" and light rotors, these should be high on your list. They have eaten my organics at a frightening rate an about to get a semi-metallic replacement pair so things should be better with regard to wear rate. Link to comment Share on other sites More sharing options...
Swart Skaap Posted July 12, 2010 Share If you are running Shimano, there should not be any washers between the caliper and fork. Postmount forks with a 160mm setup doesnt use washers, unless you are running Avid. Link to comment Share on other sites More sharing options...
Register a new accountSign in
